'50A - Cover beside Pulley Rt side
njs
07-31-2006 09:28:31
Pulley is off and now want to remove the cast cover. Have all the bolts loose and the cover moves off the pins and off the bearing--partially. This is where I stopped as something is hanging up that I cannot see? Or am I too timid here? Not sure what happens to the shaft/gear/bearing if I pull on the cover to free it from the hole that it sits in.
Thank you.
Pappy
07-31-2006 20:10:13
 Re: '50A - Cover beside Pulley Rt side in reply to njs, 07-31-2006 09:28:31
Just pull out on the cover and tap on the end of the shaft to push the bearing out of the cover. Use a brass hamnmer or a block of wood. Get some help. If you remove the nut on the end of the shaft, the bearing might come off with the cover. Either way, it will work about the same. Your cam shaft bearing tension spring will fall out when you remove the cover.
dab
07-31-2006 09:36:06
Without looking at my parts book I can�t remember if there is a snap ring on both sides of that bearing or not. I assume you are talking of the first reduction gear bearing anyways. Take the nut loose and use a block of wood to free the shaft from the bearing and all should come off then. Once you are free of the dowel pins cover should be loose to come off.
njs
07-31-2006 10:40:38
 dab '50A - Cover beside Pulley Rt side in reply to dab, 07-31-2006 09:36:06
dab,
You gave me enough detail to make me think I need to knock the shaft out of the brg. which sits on a shelf on the outside of the cast cover that I want off.
njs
