JD 3010 Overspeeding
Buckbutcher
07-31-2006 06:01:45
This too is my first Diesel tractor. Since purchase, it would tend to over rev from time to time while working it hard. This was remedied by throttling up and down rapidly. I am not familiar with the way a diesel is governed, but it seems to be related to the kill cable. I put a new kill cable on it, and it's now acting like a second throttle control, unless its pulled all the way out, resulting in a killed engine, (like it should) My questions are: Where is the shaft arm supposed to be located when installed to the cable? (all the way forward, 12:00? 11:00?,it seems to need to be at 11:00 to run right without overspeeding and to get a sustainable idle, but it is very, I mean very picky.) Second question, Does the kill cable act as anidle adjustment and top speed adjustment at the same time? P.S. I am in the process of getting an IT manual asap.
Fred in Cairns
07-31-2006 07:27:08
 Re: JD 3010 Overspeeding in reply to Buckbutcher, 07-31-2006 06:01:45
On my old 3140 I sometimes thought I had a problem because she wouldn"t reach higher revs whilst I"m working but when this happens I have found that it was because the stop knob wasn"t pushed in all the way and when I corrected this she behaved the way she should. I"m no expert but on my JD tractors the stop control arm on the fuel gizmo had to be all the way anti clockwise postion far it can go to achieve proper operation and I dont think there is any position in between indented. In other words it either all the way on or all the way off if you know what I mean. And if by accident it does happen to be somewhere in between you will not be able to acheive higher speeds not matter how much throttle you give.
Bob
07-31-2006 06:26:38
With the "kill" button pushed "IN", the lever on the pump should be against it's stop. Set it up that way, and leave the "kill" button pushed fully in, unless you are stopping the engine.
If the governor is acting goofy, as much as it's tough to cough up the $$$$, get the IP repaired at a diesel pump shop before it damages your engine!
NOTE... If the tractor has been run out of fuel, or the filters have recently been changed, or the tank is low on fuel, and there is an air leak in the suction line/lift pump area, air can enter the system, and cause weird surging, almost like the bad governor I previously described.
buckbutcher
07-31-2006 12:52:03
 Re: JD 3010 Overspeeding in reply to Bob, 07-31-2006 06:26:38
I was thinking the governer was going bad. It exhibited the need to be overhauled a couple of diffrent times. The tractor (when set up like it is supposed to be, with the fuel stop arm pushed all the way forward in the run position) will overspeed no matter what position the throttle arm is in. I think this means the IP needs a rebuild, for it acts as the governer. Is this a correct assumption? It's not low on fuel, the filters were not changed recently, and this massive overspeeding occured when backing up an incline, at low rpm that nearly killed the engine then all of a sudden-vroom! I had an all out pulling tractor sound that I quickly shut down.
Thanks to everyone that has replied!
