420C Crawler and backhoe Questions
jdjoe_97
07-30-2006 19:32:02
Guys, I just bought a crawler that has been sitting. The tracks do not move and it is not running, what is the best way to move such a beast. I plan on taking a gooseneck, and am thinking of trying to find a winch to load it with. I saw a post that said I should figure weight at 8000lbs. This has a all hydraulic loader, and a henry backhoe on it as well. Any help would be appreciated. Anyone near Atlanta, or south, any decent crane services? Joe
CH
07-31-2006 05:41:51
 Re: 420C Crawler and backhoe Questions in reply to jdjoe_97, 07-30-2006 19:32:02
We pick up dead crawlers almost everyday and a roll back with a good hydraulic winch and a smooth deck works great. One of my truckers has a roll off truck and that works slick,put the box down some wood planks then use the hook with chains to pull the crawler in the box. Works good also as it is lifting the machine as it pulls it in. Another machine is great also,but it seemed on that machine no help was there,and yes if you can bring some tools to losin the brakes it may help as that may be why it is froze that or maybe it had new pins&bushing and they are froze. You may want to think of a roll back or roll off truck to pick it up and slide it onto your trailer as even snatch blocked a 12 volt electric winch may have a hard time sliding a frozen crawler up a trailer ramp. Email me for my link when you get working on it i have all and any parts you may need. Good Luck
Roy Suomi
07-30-2006 21:28:39
You can load it with another machine..At the Deere dealership I worked at, we had to move our own machines around with another machine and some ingenuity..I once had to go with the carry-all and a 450-C dozer to pick-up a dead D-6 with a hole in the block..Pushed the D-6 around to go over the side of the carry-all[ with wood blocks]. Turned the dozer , pushed it up as far as I dared , loaded the 450-C , raised the deck,and away we went..Piece of cake!!You might loosen the brake bands before you push it around. Everything else will break loose as you move it..
jdjoe_(7
07-31-2006 05:31:07
 Re: 420C Crawler and backhoe Questions in reply to Roy Suomi, 07-30-2006 21:28:39
I am familiar with the tractor version of the 420 and the brakes. Can you easily loosen the brake bans? How is that done? Unfortunately I do not have another dozer to take with me, I only have a goose neck and it wouldn't fit even if I had one!! Some days you just wish you had a Peterbuilt and trailer. Joe
