F-I-T Question with '49 A
Jason Z
07-29-2006 15:09:04
Frank,
Hello! I was wondering if you could show me the diagram of the cork seal behind the flywheel on a "49 A. I have the flywheel off but cant seem to find this seal. I am having problems with oil leaking all over the place once the tractor has been shut off. Thanks for all your help.
Ziggy
F-I-T
07-29-2006 17:17:50
 Re: F-I-T Question with '49 A in reply to Jason Z, 07-29-2006 15:09:04
third party image
JZ:
The seal is not between the housing and the crank, but inside the oil slinger to keep oil from running down the crank and spraying out inside the flywheel. Don't be afraid to use some Permatex between the seal and the crank and the slinger. Sometimes even the cork is not enough. You'll also want to center that cover evenly around the slinger. Usually it amounts to using four strips of .003 or .004" shimstock evenly spaced between the slinger shoulder and the cover. If it is off center it can also leak.
Is there a drain hole that is clogged with sludge? That can lead to the crank area leaking since there is no where for "slung" oil to go. I just can't remember. Just gettin' too old, I guess.
Hope the picture helps.
Frank
Jason Z
07-30-2006 12:28:10
 Re: F-I-T Question with '49 A in reply to F-I-T, 07-29-2006 17:17:50
Frank,
Thank you so much! This helps alot. God Bless.
Jason Z
