Fuel Bowls again!!
dab
07-29-2006 00:21:18
I posted this on the restoration board but thought I would put it here also for it is directed more towards a John Deere tractor then anything. I have one more question for you folks, has anyone used the new reproduction fuel bowls (the quarter turn ones) I have recently bought two of them for tractors I am working on at the present time, Impressed with the quality but have heard from a couple of people that the don�t seal off. And fuel will leak by. Has anyone run into this problem and how did they fix it if they did? Once again thanks in advance for your advice.
Glen in TX
07-29-2006 08:26:54
 Re: Fuel Bowls again!! in reply to dab, 07-29-2006 00:21:18
So the repos are 1/4 turn also. Yeah the originals leaked and that's why they quit making them years ago..... I got a NOS one and it sits on the shelf because after new gaskets and repacking the shaft and nut it still leaked. When the old ones leaked you have to drain the tank and repack the valve shaft and nut. Everyone use to keep an assortment of rope packings but hard to find it now days. They should have redesigned the repo to have a tapered needle seat and it might be usable then. All the aftermarket ones you find now are junk from some other country with fittings in wrong place or wrong size and don't last long either. JD sells a good one with tapered needle seat that fits. Someone came up with plans to seal them off with O rings but I haven't had time to try that yet. You can see info on it at resto site.
Mike M
07-29-2006 06:27:03
Those by design cannot completly shut off and as they wear can only get worse. You need some clearance for the valve to turn and gas can seep by. The 3 way fuel valves have the same problem. You can only use 1 tank ,but the other will will partialy fill up due to seeping back. I like the later style that have a tapered seat at the end of the valve so it shuts off TIGHT.
