630 paint update
MIKE HANLEY
10-28-2003 11:05:40
Finished the 630 yesterday,,,,,well almost. The tractor is done, but I did cheat and send the hood and nose cone out to a body shop. (hay, it's snowing today! I'm out of weather.) That will be done next week and we will drive the tractor to the body shop and put the hood on and then touch up the hood bolts. Rather then take the time to putty up the old flat top fenders, I put on a set of after market ones. They come with the detents for both ligths, but only have one hole drilled for one head light. You have to drill out the other hole as well as the hole between them for the wires to come through. The only other differances I can see is that the after market fenders have a flat iron that goes over the mounting casting, where as the factory ones have an angle iron there. Stripped off the shipping paint and two coats of underecoating, the the classic JD green with the head light area black. Took it for a ride today and I can belive the differants with the float ride seat all fixed up!!!!! I put on new rubbers and bushings from that guy in Minn and a new shock. Then I put on the seats from that guy in South Dakota that makes them up with the springs, rather then just the foam. Been so long since I drove one with the seat riding like it should, I forgot how good it feels. Now I sappose the boys will want the two 730D's fixed up the samr way. Put on a new steering wheel and steering wheel medalion. And a new JD ovel muffler with a rain cap. Plus a new bowl on the air cleaner. When we get the hood on, I'll post a picture of it in the gallery. Even though we have owened this tractor since 1976, It felt like I was driving a new tractor. THAT IS WHY WE FIX THEM UP, you think.
Rick
10-29-2003 05:59:04
 Re: 630 paint update in reply to MIKE HANLEY, 10-28-2003 11:05:40
Mike,
Who in MN. did you get the seat parts from ?
Thanks, Rick
MIKE HANLEY
10-29-2003 08:02:56
 Re: Re: 630 paint update in reply to Rick, 10-29-2003 05:59:04
The seat parts came from MINN-KOTA REPAIR INC, 38893 CO HWY 12 Ortonville MINN. PH 320-839-3940 www.minnkotarepair.com You remove your old springs and send them in and they use your old mounting plates and install the new rubbers on your old plates. Rubbers $110 for the set Bushings $40 for the set Shock $82 (Only can be bought through JD) Seat Cushions came from The Seat Man 14215 468th Avenue, Wilmot South Dakota 57279. PH 605-432-6192. Back rest with steel back and rivots $48 seat with springs and steel corners $89 arm rests steel mounted (set) $59 $428 total to do the seat. The tect manual from JD shows how to put the seat back together as it is tricky because you assemble the spring plates under tension. I sent in my old steering wheel to MINN KOTA and they rerubbered it for $110 and the steering wheel medalon was I think $45. LOOKS GOOD!!! I put on a ovel muffler from JD as I do not like the aftermarket mufflers as they are not baffeled and are like stright pipes to the ears when running the tractor all day. $82. I think the air cleaner bowl was under $10. New screens in the nose cone was $90 and the nose cone medalon was $35. The decals were $68. That totals $448 added to the seat cost and it's $868. I don't think an extra $200 would cover the coast of GUNK degreaser, paint, thinner and paint. I had to piece together decals from JD for the 35 loader and I think that was $40. Call the whole show $1200 plus labor. MANY HOURS OF LABOR. THE HARDEST PART OF PAINTING A TRACTOR IS GETTING IT CLAEN.
Rick
10-29-2003 11:20:37
 Re: Re: Re: 630 paint update in reply to MIKE HANLEY, 10-29-2003 08:02:56
Mike,
Thanks for the info. I am looking forward to seeing pictures of you 630 when you get done. I finally bought a 630 about 6 weeks ago, it was a one owner with original paint. I grew up about 2 miles from the owner, so that part is special. It has a noise in the transmition/final drive area thats driving me nuts. For now I think the float ride seat sounds like a good winter project.
Rick
MIKE HANLEY
10-29-2003 11:11:45
OPPS""" Forgot the aftermarket flat top fenders @ $200 apiece. We also put on a new set of front tires at $55 apiece. That brings the whole show up to $1750 and it still needs a new set of back tires at about $550. Which would bring it up to $2250. plus labor. I do this so guys that are going to "restore" a 30 series can get an idea of what it will cost. All that and not a wrench put on anything mecancical.
Wayne in Tn.
10-28-2003 11:54:28
Congrats, Mike. Yes, you can be totally surprised at the difference it makes, when you put one back like it was new. I know the first time I rebuilt the steering pedastile on a 420 tricycle, I could not believe how much better it drove. Guess thats how they felt when new....
