WOW! I got a REAL tractor now! YOU guys RIGHT HERE were a big help in steering me to the right path of repair on my thread DLTX71 OR DLTX72?. The 1946 "A" runs like a new tractor now. Last year I had trouble getting it to pull good, and finally go it set good enough to pull the hayrack in 5th gear at our motorcycle rally. This year I could NOT get it to pull its own weight in 4th enough to close the governor from wide open. Intake stack was full of mud dauber nests. Took the air cleaner assembly off. Used lots of water through an improvised nozzle to reach around the corners and lots of compressed air. Finally got it cleaned out. Got the special drill bits & tiny brass plugs from Robert's Carburetors today. Even though I could get 130# PSI air through the Idle circuit, it took some patient drilling to clean the rust out of the idle passages. NOTE: Don't be fooled like I was, GET THE BITS!!! Got it together, set the load 3/4 turn open, idle 1 1/2 open, and fired it up. Headed out the driveway in 5th gear. WHAT POWER! Got on the road & put it in 6th. Eased in the clutch and she pulled away with no problems and got up to speed quickly! Running a tad rich, so screwed the load jet in a 1/8 turn. Then set the idle jet in a smidgeon, too. And speaking of steering, I had better remember to tighten the steering wheel nut! THANKS GUYS, YOU ARE THE GREATEST!!!!
