Best way to get wheel centers on Axel
Soldner
07-28-2006 10:33:24
I was wondering how everyone gets the cast centers on the axel.. I got one about one inch, but it takes its with a mallet to move it.. What works best!? Thanks
johns48b
07-28-2006 14:37:42
 Re: Best way to get wheel centers on Axel in reply to Soldner, 07-28-2006 10:33:24
die grinders with small wire brushs on them work wonders in a tight place like down in a groove. don't forget the safety glasses!
James Howell
07-28-2006 14:02:40
Agree with all methods mentioned above.
I use a large grinder with both a vertical round wire brush and a flat round wire brush.
Use a small file to remove any "mushroomed" ends from the splines.
Use a small wire brush to clean the splines inside of the wheel hub.
You might put some graphite powder on the axle before mounting the wheel. This worked great on my 70 Diesel.
With both the splines on the axle and hub clean, you should be able to "wiggle" the cast wheel on.
Use a wooden block, preferably hardwood (oak), against the cast wheel hub when using a hammer. I just replaced a solid cast center wheel ( $125 ) on my 43B that a previous owner had broken in two pieces at the hub.
I only use PB Blaster and/or WD40 lubricant on axles that have been neglected by previous owners.
Please do not paint your axles. You will be glad the next time you �wiggle� the cast wheel off by hand.
machinery-man
07-28-2006 12:38:27
I would clean with rotary brush. Wouldn"t recommend lubricant as I had trouble keeping them tight with lubricant.
Glen in TX
07-28-2006 11:34:31
Clean more and use wire wheel, file off nicks and lay file down in splines to get them clean, & emory cloth till it slides on easier.
Soldner
07-28-2006 12:27:13
 Re: Best way to get wheel centers on Axel in reply to Glen in TX, 07-28-2006 11:34:31
Will do, Thanks
BUDD
07-28-2006 11:02:54
Clean the splines on the axel REAL good. Mine move by hand easy, but I cleaned my axels of all dirt and rust.
BUDD
buckeye al
07-28-2006 15:12:02
 Re: Best way to get wheel centers on Axel in reply to BUDD, 07-28-2006 11:02:54
I'm with Budd.
Once off, I clean the splines inside & out then oil 'em up & they easily slide on AND off for me.
The only "trick" I know of is that they're naturally off balance and you have to both "feel" and "counter" that balance before they move nicely! To slide 'em ON, I push with both hands up top & the toe of one foot at the bottom BUT, I push a bit harder on the bottom than on the top! To slide 'em out, I straddle the axle and push with both feet and both hands but but I push a bit harder on the top than on the bottom. Seldom have any troubles! Might not move 'em for years but "feeling that wobble" makes ALL the difference but ONLY after all the "excess rust" is out of the hub & off the axle.
This is all ASSUMING the clamp collar is on the OUTSIDE instead of inside facing the axle housing. If the clamp collar is inside, then the balance is backward from what I said above.
