2240 transmission problems
Shelton
07-27-2006 15:54:57
Has anyone else had major trasmission problems with their 2240?
Pete/ME
07-28-2006 02:48:49
 Re: 2240 transmission problems in reply to Shelton, 07-27-2006 15:54:57
No, #18399L. About 900 hrs.
Shelton
07-28-2006 04:09:13
 Re: 2240 transmission problems in reply to Pete/ME, 07-28-2006 02:48:49
Mine tends to like to "lock" itself in Range I every once in a while. I can normally rock it loose, but is there a permanent solution?
Mike M
07-28-2006 12:52:14
 Re: 2240 transmission problems in reply to Shelton, 07-28-2006 04:09:13
Is yours sticking in PARK ? They had some kinda goofy shifter modifacation they put on those. The later ones used a hand brake to solve this.
Shelton
07-28-2006 13:17:19
 Re: 2240 transmission problems in reply to Mike M, 07-28-2006 12:52:14
No, it is usually between Range 1 and Reverse. It is stuck in Range 1 right now and I will probably have to take it apart this time because it won't rock back in. Ever had one of those apart? It is getting them both back in and lined back up that worries me.
Mike M
07-28-2006 17:25:50
 Re: 2240 transmission problems in reply to Shelton, 07-28-2006 13:17:19
I have had very few of those "modern" models apart. I think maybe 2 ? and not for that problem. Do you have some kinda service manual ? if not I'd at least get an I & T. I'd for sure take that top off and have a look around. I'm not sure if those shifters are in the top cover or in the trans. case. I'd look for bent stuff or burrs check out the detent springs and balls and maybe it even has a cross drill passage for an interlock that's binding or worn out.
Shelton
07-28-2006 18:02:24
 Re: 2240 transmission problems in reply to Mike M, 07-28-2006 17:25:50
I have an operators manual but no parts manual and I was just looking this morning at the local farm store for a copy...none, so I'll have to order it. I've had a 2020 apart several years ago and it was a real pain to put back together and get both lined up right. The 2240 has the added safety lock to deal with also.
Pete/ME
07-29-2006 03:03:31
 Re: 2240 transmission problems in reply to Shelton, 07-28-2006 18:02:24
Try "JD Parts" at the JD site. It's pretty much the same thing as a parts manual.
Shelton
07-29-2006 11:40:10
 Re: 2240 transmission problems in reply to Pete/ME, 07-29-2006 03:03:31
I took it all apart today. I had to remove the panels and the shifter locking gaget to get to it. They actually pulled pretty easy and went back almost as easy. It had jumped out... I replaced the gasket and put her back together. I'm going to watch it, the right portion of the range shifter looked a little worn and I may need to replace it. If it jumps out again I will probably do that. Thanks for your help.
