301A seat
TomIn
07-27-2006 07:30:59
I have a 301A with a shot seat cushion. Does anyone know if the aftermarket cushions for a 1020 will fit? (The pictures look the same, but Deere lists different part numbers). Also, does anyone have any suggestions for an aftermarket exhaust system? I have the gas engine with rear exhaust. It looks like the Deere price is nearly $400 for the exhaust pipe, muffler, heat shields, etc.
Ten-Twenty
07-27-2006 16:37:46
 Re: 301A seat in reply to TomIn, 07-27-2006 07:30:59
Tom,
Did you buy your 301-A from the church in Muncie, IN? The one with the flail mower and front blade?
TomIN
07-28-2006 00:56:20
 Re: 301A seat in reply to Ten-Twenty, 07-27-2006 16:37:46
That's the one. I bought it sight unseen. Do you know anything about it? My email is [email protected] if you can provide any info.
Ray
07-27-2006 15:32:45
I've got a 300 that needs a seat cushion.JD tells me it's no longer available,you have to buy the 2020 seat and different mounting brackets to make it work.I'm going to get it recovered someplace,the new seat and brackets are over $200.
Glen in TX
07-27-2006 07:50:16
You might check with a TISCO dealer on those.
woodsonline.com (to find TISCO dealer locator)
Or also try these: aiproducts.com (check dealer locator)
TomIn
07-27-2006 11:21:50
 Re: 301A seat in reply to Glen in TX, 07-27-2006 07:50:16
Thanks Glen
I emailed K&M. They had the seat I needed (model 2020) The gentleman there told me that Deere uses the identical seat on several different models, but assigns different part numbers depending on the model of tractor.
Ray
07-29-2006 11:07:53
 Re: 301A seat in reply to TomIn, 07-27-2006 11:21:50
That guys pulling your leg,i have a 2020 also and the seat is different.
TomIn
08-07-2006 09:07:08
 Re: 301A seat in reply to Ray, 07-29-2006 11:07:53
I got K&M's seat UPS last week and put it on over the weekend. The bolt holes were a perfect match. I don't know about the covering because there wasn't enough left on the old one to tell.
