G Shifter....
JDGnut
07-26-2006 20:56:01
third party image
I broke my G shifter base a few weeks go.. Been running a few weekend with it broke.. Yea.. I was pulling it.. And I had it locked in gear.. the pivot ball on the shifter was in really bad shape.. even missing a few pieces.. I got another base and shifter.. (I think its my last one.) I just don't want to break this one... JDGnut
DP
07-27-2006 21:06:14
 Re: G Shifter.... in reply to JDGnut, 07-26-2006 20:56:01
Hey there Gnut, some people sure go to great lengths to keep folks from knowing what gear their pulling in! LOL
JDGnut
07-28-2006 11:33:10
 Re: G Shifter.... in reply to DP, 07-27-2006 21:06:14
Yea.. Next I'll remove the Hi-Low shifter to really throw them off... thought about building a 3 lever shifter.. one for each sliding rail... That would keep eveyone off my tractors.. lol... JDGnut
JDGnut
07-27-2006 06:00:51
Steve.. I was pulling when it broke.. not sure if it broke when I shifting in to a forward gear.. or reverse.. Just reached for the shifter.. and was surprised when the whole shaft pulled out of the transmission... I've had the entire trany out.. Not worried about the bearings.. there are a few worn gears.. (It got the best of the two transmissions I had..) I'm always curious as to how they like to pop out of gear.. with straight cut gears.. there really should not be a "side load" I know many JD that have a lock to keep them in gear... JDGnut
G/MAN
07-27-2006 07:33:21
 Re: G Shifter.... in reply to JDGnut, 07-27-2006 06:00:51
50+ year old parts with who knows how many thousands of hours on them, wear and weak shifter detents all contribute.
JDGnut
07-27-2006 10:12:11
 Re: G Shifter.... in reply to G/MAN, 07-27-2006 07:33:21
Yea.. no telling how old those parts are.. I don't know which tractor they orginally came off... I thought I had good detend springs.. and shafts.. Might shim them a little.. or cut some new notchs in the shafts..
Steve Crum
07-27-2006 04:52:56
You didn't state how you broke your shifter, but if it broke due to an internal problem in the transmission, the last thing I would have been doing is continuing to run the tractor. Especially pulling it, until I found out why it broke. You next post will likely read 'destroyed the transmission in my G' Replacement gears, shafts, bearings needed.
Anybody know a good cast iron welder?
