Glen in TX ..... Lost info
Haze
07-26-2006 15:23:36
Don't know what I did with the reel shaft bearing numbers that I got from Glen in TX, I need to replace the drive reel bearings on a JD 851 Side Delivery Rake.I thought I saved the info but must have had a brain cramp.Glen, do you still have that rake picture? Many thanks, Haze.
Glen in TX
07-27-2006 07:46:12
 Re: Glen in TX ..... Lost info in reply to Haze , 07-26-2006 15:23:36
Yes, still have the info. Your email isn't open or I must have lost it. Email me if you still need it. [email protected]
If you meant the 16 bearings for the reel bar spindles they are JD8585 and JD8546 and JD still has those and dimensions are shown on JD Parts online. I forget which bearing now but I had found that a aftermarket 7109 magneto bearing would substitute for one for less $$ as 8 times near $40 + cost of other bearing takes the fun out of it fast.
Glen in TX
07-27-2006 10:43:27
 Re: Glen in TX ..... Lost info in reply to Glen in TX, 07-27-2006 07:46:12
JD Parts
