Help on Water tube on a 1940 B
IronHorse
07-26-2006 11:29:23
My Steel tube to the top of the rad is leaking again. I have been fixing it with JBweld up to this point, but know I will soon have to replace it. how bad of a job is this and how is attached to the engine is it a press fit or just how? where to get the pipe is it something I can make? also have a rear wheel seal leaking deere say they dont make the felt pad anymore looking for a suggestion on how to stop the leak on the seals
thanks
P Browning
07-28-2006 05:53:24
 Re: Help on Water tube on a 1940 B in reply to IronHorse, 07-26-2006 11:29:23
In reviewing all of the posts thus far, I have two comments. (1) Accomodating the bend in the pipe -- If you are a bit adept at angles, cut the new pipe at a slight angle and then weld it back together to achieve the desired angle, and (2) Take reference pictures BEFORE removing hte old pipe to help you orient the angle in the right direction. (PatB)
john dear
07-27-2006 18:09:13
F.I.T. is right. I replaced the pipe on my unstyled B. Cut the old one next to the casting. Peeled out the left over pipe. Ground new bevel on inside of casting. Pipe was close to exhaust pipe tubing size so we used that. Didn't put the kink in. Made the pipe about 6" or so shorter than original and use a little 'extra' rubber hose. Up behind hood so only really nosey correct police find it. Brased the new pipe in. Takes a good bit of heat to get the entire casting hot, then braze away. Make sure you sand blast or bead blast all the flux off. Paint tends to come off later with any that is left behind.
machinery-man
07-27-2006 08:20:53
If you clean the old metal out of the housing, you can taper the inside of the house and nickle weld the new pipe in place. You will need to be a good welder, heat the cast iron part and then nickle welds smoothly and continuously. I suppose you could braze if you can get enough heat on it, but that really difficult. The nickle will work but keep it hot and let it cool slowly. With the inside beveled back this will allow for fill area and then you can lightly grind the face. It"s not necessarily an easy job due to the nature of assembly.
Ravgardner
07-26-2006 12:53:14
I'm replacing my second upper water pipe right now. I took it to a professional welder; he sure knows his stuff. F.I.T. is right about the heat, it takes a ton. We cut most of the ppe off. Then torch cut two grooves in the pipe inside the casting. Then heated and used a hammer and chisel to peel the rest of the pipe away from the casting. It was the welders opinion that it was silver sodered in place. So we silver sodered the new one.
As far as pipes, the H pipe I replaced with a iron pipe from the welders' stock. The model A pipe I'm working on now was bought from K&K. It has a bend that I'm not sure we could duplicate. Need to have the right jig made.
F-I-T
07-26-2006 11:39:59
Ironhorse:
You have some questions that have not so nice answers.
The water pipe is brazed into the casting that is bolted to the top of the block. To replace it properly, you need to find the pipe portion (K&K Tractor parts has those I do believe as well as others), and then remove the old casting/pipe from your block, heat to remove the old pipe, and then braze the new one in. Takes a fair amount of heat. Some pipes on certain models even have a kink that must be oriented correctly. Watch that.
The axle seal leak issue is not solved by replacing the outer felt. That felt is there just to keep dust out of the outer bearing, not to hold the gear oil in. The gear oil is sealed out of the axle housing by means of an oil seal lodated inside the rear end between the bull gear on that side and the axle shaft. You have to remove the rear cover to access this. Not a tough job, but dirty and heavy. I recommend that you do both sides while you're in there.
Frank
