JD 60 Power steering.
Stuart
07-26-2006 07:39:37
I own a 1954 John Deere 60 with Power Steering. The problem I am having is that it pushes oil out the breather inside of the oil fill plug. I also notice that my pump, which was recently rebuilt is leaking between the mating surfaces. There are not gaskets that the parts book show, there were no gaskets when I took it apart a couple of years ago. What are you guys sealing these surfaces with. I have access to a large sander like they use to sand a cylinder head up with to true it up, should I use this or will the tolerances be to close after I sand the surfaces and cause a lock up to the pump. thanks for all the help
F-I-T
07-26-2006 08:33:36
 Re: JD 60 Power steering. in reply to Stuart, 07-26-2006 07:39:37
It does sound like your pump might even be sucking air. This can cause the P/S oil to foam and that can make it's way out that cintered brass breather pellet. Is the oil level normal after a night of settling down?
On the sealant, I have always used brushable Permatex (I'm a little old fashioned I guess) or Indian Gasket Shellac if the surfaces are really, really flat. In fact, if the surfaces are dead flat, I might even thin it a bit so it goes on like a film. I have even used the copper spray on one pump, and it turned out fine.
But, I also have a lapping plate, so I take those pump halves and twirl them around the lapping plate with course and then fine SC compound (Clover brand is the tried and true name) and those two surfaces will be so flat that with a film of oil they will wring together so tight that you have to twist them to get them apart. If you have access to a lapping plate, or know a shop who will let you use theirs, all it takes is time to get it near mirror smooth. In fact, it will be optical flat-true if you are familiar with that sort of measuring. Cetainly the microfinish will be in the order of a 5 or less. You won't get there with a sander.
If you do not have access to a lapping plate, and still want to get it smooth, try taking a full sheet of a GOOD grade of 400 or 600 wet/dry silicon carbide paper, and using a light film of oil on the back, smooth it onto a sheet of picture frame glass. A little light oil on top and you can swirl the piece in figure 8 patterns and as you work you will see the high spots shine. Work until the finish is uniform. Switch to some 1200 if you want the finish even smoother, but 400 ought to give you close to the ground finish it had when new.
At this point, nearly any sealant will work, in fact the thinner the better.
Frank
GPULLER
07-26-2006 08:16:51
Sounds like the seals on the fanshaft side of the pump are bad. My 720 was doing the same thing, it was sucking oil from the governor housing though the fanshaft and filling the P/S, then pushing the excess oil out the vent. When you replace the seals you will need to get two seals from Deere. Install them with the lip of the inside seal facing into the pump, the lip of the outer seal facing the fan shaft.
When I put my pump back together I used the sealant that is used on motorcycle engine cases.
G/MAN
07-26-2006 07:46:19
They probably originally used something like a shellac. Something like the Loctite form-in-place gasket or gasket elminator should work fine to seal that up.
