Which John Deere?
Bill A
07-25-2006 18:46:23
I need to buy a JD tractor with at least 40HP to use for brush hogging, etc. I want to spend under $8500. Which models should I be looking at and which should I stay away from?
MLD
07-26-2006 05:54:35
 Re: Which John Deere? in reply to Bill A, 07-25-2006 18:46:23
The only one to stay away from is the 2010, even the book JD tractors & equipment states it did not recieve enough testing & was known for durability problems. No matter which model or brand you buy its only going to be as good as the person that maintained it, if it was abused, you could get a lemon.
CLW
07-25-2006 20:02:40
The 2020 may be OK but you take a big chance with the 2010. Some are good but some are VERY bad. Are you looking for a two cylinder or a newer tractor? A 620-630 would began in the $3000 range with 45 HP.
CLW
William Sill
07-25-2006 19:06:43
a JD2010 or a 2020 should work fine price should be around 4500-6500
