B running poorly
Grant Miller
07-25-2006 16:25:42
I had a problem a week or so ago with my B not running too well. We narrowed it down to a plugged air intake. I cleaned it out with wire and it seems that it is pretty well cleared out. When I put the oil bath back on the bottom of the air cleaner, it tries to suck the oil out and will die. If you let it run with the oil bath off, it runs pretty well, but it won't run past 3/4 throttle. Also, changing the the load needle when it is sitting still and running at half throttle has no effect on the engine. Do I still have an air restriction problem? Are there more problems on this tractor?
Thanks!
P Browning
07-26-2006 01:31:56
 Re: B running poorly in reply to Grant Miller, 07-25-2006 16:25:42
Grant -- I was hopeful we had you aimed in the direction of success. But alas, there remains grief. Let us recap things first. As I interpret your tractor description, your late B should have DLTX-67 carburetor with WICO XB distributor. Further, you had obstruction in the air inlet stack and believe that is now cleared. But then we have (1) engine attempts to draw oil from air cleaner bowl & dies, (2) With the air cleaner bowl off, it seems to run OK but will not accelerate above 3/4 normal engine speed, and (3) When sitting and running (sort of a fast idle) the LOAD needle has no effect.
1. Perhaps a baseline look at some basic stuff is in order here -- lots of water under the bridge and I know you are frustrated. Let's eliminate a bunch of seemingly innocent but significant variables. WITH THE ENGINE NOT RUNNING: (1) Check governor-to-carb linkage, (2) Revisit point gap - should be in the 0.014- 0.017 range (0.015 nominal), (3) Ensure sparkplug gap is 0.030 nominal, (4) Recall here -- verify the fuel nozzle spring installed so as to support fuel nozzle in the full-up position, (5) Re-initialize carb needle settings for IDLE (1 - 1-1/4 turns) and LOAD (3/4 - 1 turn).
2. Looking back at the three complaints above, # 3 doesn't bother me much. # 2 is a puzzle which may be resolved in part by correct governor-to-carb linkage and verification that the fuel nozzle spring is in place, but # 1 sure hints to me of some continuing issue with the air intake.
3. PREPARE TO RUN ENGINE: Again - disconnect the carb air inlet elbow.
4. ENGINE RUNNING: Repeat LOAD & IDLE pathway tests. Check for acceleration to full engine speed. If it seems to be running normal, try trimming the IDLE adjustment. Trim out of the LOAD adjustment demands a load be placed on the tractor - difficult to get a grip when just running and standing idle other than to see the engine "gun up" quickly in response to sudden throttle advance & then a quick settle in when RPM is attained. If all is okay to this point, you now must go back to the air inlet path.
5. AIR INLET PATH: I am a little stumped here because of not being real sure what the engine will act like at this point, but if all is well through paragraph 4 above, here is the drill I think is needed. SHUT ENGINE DOWN. Reconnect the air inlet elbow & remove the air cleaner oil bowl. Run the engine up and hope fully all will be well. If not, you have a restriction in the wire mesh part of the air inlet path. If all is well, then try installing the bowl without oil. If engine faults, you still have restriction in the air stack. Having normal engine operation at paragraph # 4 is essential to making sense out of this paragraph (# 5).
6. If you want to chat a bit about this beast, give me a call. My phone number is pasted all over the JD-H Restoration Site. (PatB)
Grant Miller
07-25-2006 18:26:07
 More info on B running poorly in reply to Grant Miller, 07-25-2006 16:25:42
I had the carb off as well as the intake elbow tube and air cleaner assembly. I know that the carb and elbow are clear. I pulled the bowl off of the carb and it is clean. I also pulled all of the brass plugs to ensure that all of the passages are clear in the carb and pulled the main jet tube to make sure that it was clean. When I cleaned the intake tube that was left on the tractor, I worked until i didn't get anymore dirt to come out. I also checked to make sure that the float level is at 3/4".
Mike M
07-26-2006 06:42:13
 Re: More info on B running poorly in reply to Grant Miller, 07-25-2006 18:26:07
Since you are having problems with the air cleaner cup on and not off I think I'd be taking the whole air cleaner assembly off and take the bolts out that hold it together and pressure wash the mesh filter and the air stack. You can test the mesh for flow with the water too.
johns48b
07-25-2006 17:56:20
i'm guessing that you've sucked something into the carb from your air breather. you probably need to remove the air clearner stack and get it out where you can give it a good cleaning. on my b when i cleaned it i found a hole in the bottom of the casting that i assume is meant to let some dust out, but mostly rain water. you need to remove your carb and clean it good. glen in texas, f-i-t and pat browning may give you some more insight in a while. go to JDHPubs.com and read his info on rebuilding h carbs. the same info will pretain to your b. i'm betting on the dirt dobbers in the air intake. good luck
