2240 Hydraulic vibration
burlap
07-25-2006 14:43:58
I have a 521 loader on a 2240 that sometimes vibrates as I raise the bucket loaded or empty. The hoses vibrate and the vibration can be felt through my feet. When it does this the movement of the loader slows noticeably. I checked the fluid and it may even have too much. I hesitate to take the filter off because it is so difficult to replace without it dripping that I hate to do it if it's not time and it hasn't been on that long. If I don't hear any good ideas I think I will take it off tomorrow and check it out. Any ideas how to replace it without unseating the oring. Thanks, burlap
Roy Suomi
07-25-2006 22:26:28
 Re: 2240 Hydraulic vibration in reply to burlap, 07-25-2006 14:43:58
Could be a few different problems..Hyd vibrations can be caused from oil supply problems , like; suction screen in trans housing , pressure control valve stuck in bore , filter relief valve stuck open , rockshaft valves leaking oil , oil pressure settings , pistons stuck in bores of hyd. pump..Take your pick..As far as your filter gasket goes...I grease them into place...They'll stay with grease....
