3 5/16 diameter shaft?? Rear axle?
Tyler-MO
07-25-2006 11:50:12
I'm trying to repair a two-way integral plow that uses a 3 5/16" diameter x 33" long solid steel shaft that the plow pivots on. The original is broken and I need to find a substitute for it.
I intend to use an tractor rear axle shaft for this purpose. Can anyone out there tell me of any tractor that used this size axle shaft (it can be longer than 33" but not shorter).
Thanks for any help provided!
Tyler in Missouri
BillNNY
07-25-2006 14:54:10
 Re: 3 5/16 diameter shaft?? Rear axle? in reply to Tyler-MO, 07-25-2006 11:50:12
The 4020 and 4230 have axles that use 3 3/8" ID bearings on the outboard of the axle. Maybe this might work for ya.
3020 axles are too small (3.18***) and 4250 (86mm)axles are too big.
HTH
Bill
