Question on JD 420
Ken Reese
07-25-2006 08:58:47
I don't have a parts manual for Model 420 so I'm hopeful someone out there can answer this basic question.
What size bolts/studs fit into the bores at the bottom of the front which hold the front weights on the tractor? There are two bolt holes below the grille assembly on which the weight is mounted.
Thank you,
Ken
Tommy Eldridge
08-02-2006 18:40:13
 Re: Question on JD 420 in reply to Ken Reese, 07-25-2006 08:58:47
You can go on John Deere Web Parts and look up most parts for a 420.
john dear
07-25-2006 16:54:59
5/8" course thread if they haven't been damaged and drilled and tapped larger.
MLD
07-25-2006 09:20:51
Use whatever fits!!!! Use a tape or ruler to measure the size of the hole!!!
Ken Reese
07-25-2006 10:50:07
 Re: Question on JD 420 in reply to MLD, 07-25-2006 09:20:51
Unfortunately, I don't have access to the tractor at this time.
