Gasoline in the Oil
Dean Lydey
07-25-2006 06:13:00
I've got 1950 B that up until just recently has run great. 2 weeks ago the getting it started was more of a challenge. After a few unsuccessful attempts I decided to change plugs. She came to life but wow...lots of blue smoke. 20 minutes into mowing the smoke subsided by 80 percent. In addition, about half way through mowing I noticed a slight decrease in oil pressure. The needle was closer to the "M" instead between the "M" and "H".
This last Saturday I had difficulty again starting the tractor. Even with fresh plugs again it didn't start. I remembered the oil pressure decrease and checked the oil. I run 30 weight non-detergent. The oil level was OK but it came out very thin and definately smelled of gasoline.
I'm looking for help as to what maybe causing the gas in the oil and how to bring my little B back to life.
Thanks in advance
jubilee johnny
07-25-2006 08:26:42
 Re: Gasoline in the Oil in reply to Dean Lydey, 07-25-2006 06:13:00
I had what I thought was a similar problem to yours when my oil level on my 70 gas kept increasing. I installed a gas cut off switch and still the problem. Turns out it was a bad seal in the power steering that was getting ps oil in the crankcase. good luck.
John T
07-25-2006 06:28:12
Dean, anytime you shut the tractor off you should turn the gas off like at a sediment bowl or other shut off. The cause of gas in the oil may well be the carbs needle valve n seat assembly and/or the float are now working properly to shut the gas off at the correct carb bowl level n shes running over n flooding the carb n down into the crankcase. In the event shes running over rich and/or black smoking out the exhaust stack you may wanna check the air cleaner and its lower bowl (full of crud or water) and the inlet air piping and make sure the choke is opening fully n staying open and check out its top load needle adjustment also.
Over rich running or a plugged up air intake or breather can cause gas in the oil but at a much slower rate n build up then a faulty needle n seat or float as discussed above.
Give her a good oil n filter change then check the cabs float n needle n seat for leaks and the air cleaner bowl n inlet piping and check the choke n adjust the carb n see what happens. I assume it isnt equipped with nor didnt have an auto shut off type sediment bowl assembly added at some time cuz their diaphrams can leak n get gas in the oil???
John T
johns48b
07-25-2006 18:17:50
 Re: Gasoline in the Oil in reply to John T, 07-25-2006 06:28:12
good answers john t only i'd solve the problem first before changing the oil. however, don't crank the tractor with the gas still in the oil.
Dean Lydey
07-25-2006 06:40:41
You guys never fail me! Every question I've ever posted has been answered with good suggestions. Thanks.
We did get a fair amount of HEAVY rain recently and my little B has been out of the shed with only the exhaust stack covered..not the intake. Also, I don't shutoff the gas at the sediment bowl. I'll start.
Thanks again.
Dean
