4430 Remote Valve Problem
FCLW
07-24-2006 20:53:25
I'm having trouble with the remote valve on my 4430. It only works one way. It will extend the cylinder but not retract it. If I switch the hoses, it retracts but wont extend. Any Ideas?
WTW
07-25-2006 09:06:08
 Re: 4430 Remote Valve Problem in reply to FCLW, 07-24-2006 20:53:25
You probably have one of two things causing your problem, One possibility is one of the actuating cams has come lose and is moving when operating the valve. You can check the cam retaining screw for each cam by simply removing the plug on each side of valve box (1" socket) and check screw for tightness. Screw will be under this plug and will be either an allen type head or take a flat bit screwdriver to tighten it. Just snug them tight by hand, The plug you remove to gain access to these screws (one on each side) will keep screw from falling completely out because plug will limit how far screw can back out. The other more likely cause is you have lost one of the valve rollers that ride on the actuating cam. This will require the valve to be removed to inspect and repair. No big deal to an experienced tech that knows how to work on these, as previously said there is tools to adjust them but if you understand and know how they work they can be adjusted closer and better without the special tool or air pressure. I have been working on these valves since 1977 and quit using the special tool in 1981. I never have used air pressure. The trick is maintaining neutral position when adjusting clearances. The correct clearance adjustment is very important to make this valve function correctly. Take it to an old seasoned dealer tech as it should be a walk in the park for him. DW
G/MAN
07-25-2006 13:35:29
 Re: 4430 Remote Valve Problem in reply to WTW, 07-25-2006 09:06:08
Just did a 4650 valve today, which are obviously a little simpler than the 40-series and older valves as they don't have the retention screws on the cams. Air pressure works slick as a whistle. Just rig up shop air to a male tip and a needle valve and plug into one side. Adjust the valves on that side by putting your finger over the pressure hole so you know exactly when to stop turning the screw and by listening in the housing for return-side air. Once they stop, back the pressure side off about 1/4 turn and the return side off about 1/8 turn so you know the return valves open sooner than the pressure valves. Then you can shut off the air supply, wait a few seconds and move the lever to see if the valve maintained air pressure. I've done dozens of SCVs, and the air pressure method can verify that everything is kosher before reinstallation. Haven't met anyone yet that doesn't get an o-ring in the wrong spot or something every now and then.
donmyeil
07-25-2006 04:48:10
Sounds like you are going into the float position. Should be a little flipper to stop the lever from traveling to float.
FCLW
07-25-2006 06:03:29
 Re: 4430 Remote Valve Problem in reply to donmyeil, 07-25-2006 04:48:10
No I'm not putting it in float. I have the plastic blocker in place. It's when I pull back on the lever that I get no response. I also checked the linkage and it is fully moving the little lever on the remote behind the cab.
G/MAN
07-25-2006 07:40:48
 Re: 4430 Remote Valve Problem in reply to FCLW, 07-25-2006 06:03:29
If it's moving the lever at the remote both directions as the lever is moved both directions, you've got an internal problem. Most likely a blown o-ring on one of the spools, rather than a mechanical issue, but anything is possible. Pretty simple to unhook the linkage and unbolt the box to take it in to be checked and repaired. They're not terribly hard to repair, but experience makes them much easier, and you either need a special tool to adjust the valve clearances, although that thing is kind of a joke. We use air pressure to adjust them in 1/4 of the time it takes to use the tools, and you can leak-check them at the same time.
