730 Rack setting
Ferd
07-24-2006 16:20:43
Trying to check my injector rack setting on a 730. My manual says to open the throttle to "fast idle" and the rack should read "13". I found the rack which appears to have several "notches" but I don't see any number "13". Does that number refer to a notch? If so, what does the notch line up with? The manual isn't very clear.
Thanks for any help.
GPULLER
07-25-2006 08:31:22
 Re: 730 Rack setting in reply to Ferd, 07-24-2006 16:20:43
Yes the longer marks on the rack would be 0, 5, 10, 15 etc. Rack setting 13 would be 3 small marks after the 10 long mark. It's kind of hard to see the marks, it helps to have a light and a small mirror to look in there.
730 Mike
07-24-2006 21:09:35
I must have done something wrong because my rack opens as far as it will go but doesnt over fuel runs great pulls even better. It did seem to affect my idle positions some.
Mike
msb
07-24-2006 20:16:35
If I remember right there are longer hash marks on 5 and 10, so 13 would be 3 marks beyond the 10 hash mark.Setting the rack beyond that will cause an over fueling situation.It will not affect the high idle setting.That is controled by the governor.
