JD 4020 Info
mtrim
07-24-2006 12:00:31
I am looking for an education on the "20" series tractors, particularly the 4020. I need explanations about model differences, changes over the years, etc. Can someone please direct me to a good site or reference?
Ferd
07-24-2006 16:29:34
 Re: JD 4020 Info in reply to mtrim, 07-24-2006 12:00:31
The earlier 4020s up through 68 had the hydraulic controls in the dash, were 24 volt and had a round muffler while the later series had the hydraulic controls in a console beside the right side of the seat, were 12 volt and had an oval muffler. The later ones also had a dry air cleaner while the earlier had oil bath (except the 68 model). I have one of each and find the later one much easier to operate because of the hydraulic controls location. Also, the 12 volt system is less troublesome, although mine has not given me any trouble.
Gerald J.
07-24-2006 18:54:00
 Re: JD 4020 Info in reply to Ferd, 07-24-2006 16:29:34
Air cleaner changed from oil to dry at SN 99,000. Hydraulic controls and significant engine changes happened at SN 201,000.
Gas and LP 4020 were always 12 volts, negative ground, unless supplied with an aircondioned cab. Then both gas and diesel came with a 12 volt negative ground alternator.
I got these details from the parts book edition that covers my 1968 gas 4020 SN, 184,xxx.
Wiring harnesses changed drastically around 99,000 and again at 201,000.
Gerald J.
HTR
07-25-2006 08:32:07
 Re: JD 4020 Info in reply to Gerald J., 07-24-2006 18:54:00
The 4020 gas and LP with generators were positive ground.
Jon (IN)
07-24-2006 13:43:25
Here's a good start..... Link
