bolts
70D
07-24-2006 11:52:14
Question I'm putting some wieghts on My 70 John Deere the wieght are just extra that where laying around the shed so I don't have all the bolts I have 3 inch bolts but I was thinking that you need longer ones on the wheel hub like 5 1/2 inch is this correct or will the 3 inch bolts I have work
720Deere
07-24-2006 16:50:55
 Re: bolts in reply to 70D, 07-24-2006 11:52:14
The correct JD wheel weight bolts are 2-3/4" x 5/8" square head bolts with a serated shoulder that drives into the wheel or weight and stays in place. They work nice but they are rather expensive. The last time I bought any they were around $4.50 each. Other parts have gone up in the last year so I imagine they have as well. You can get regular square head bolts from you JD dealer for just over $1.25 each. They will work fine if you intend to put the weights on and leave them on. If you remove or add weights with any frequency, the weight bolts are the ticket as they make the job a lot easier.
You could always use regular square heads and JB weld them into the weights.
70D
07-24-2006 11:53:36
I forgot to put these are rear wheel wieght
SMASH
07-24-2006 14:20:02
 Re: bolts in reply to 70D, 07-24-2006 11:53:36
I just had to remove some weights for a pull. First time I have hade them apart. All bolts were 3 inch. When you add another weight the bolts go in the previous monted wieght. Make shure you use square head bolts. Previous owner used regular bolts, and they were a pain to get off.
