JD 4020
Zach Phillips
07-24-2006 09:53:58
We have starter problems and the batteries won't keep its charge. Does any one have any ideas?
Gerald J.
07-24-2006 18:57:55
 Re: JD 4020 in reply to Zach Phillips, 07-24-2006 09:53:58
Batteries implies 24 volt and diesel.
Check the starter for a pile of brush dust causing a ground from one of the brush holders. Then check the starter windings for a stray ground. The windings should be insulated from ground all over.
If you have a 12 volt accessory like a light or radio that can upset the balance of charging between the two batteries.
If you don't run it several hours per start the 10 amp generator won't get the batteries up to full charge.
Just a few things to look at that are the most common to give problems that I've heard.
Gerald J.
Brent in WI
07-24-2006 17:03:33
A little more detail on the symptoms would help like do the starter problems happen after the batteries go bad or are there two separate problems? Does the dash gen/alt light stay on? A bad starter shouldn't keep the batteries from taking a charge. But obviously batteries not charging will cause the starter not to work very well. Is it 24 or 12 volt? Does it have a generator or alternator etc.? There have been many posts about 3020/4020 electrical problems recently and you might want to do a search on this site for review.
Brent
Mike M
07-24-2006 11:01:42
Get the starter looked at ?
