3010 Hydraulics go up OK slow to go down?
GnRPaint
07-24-2006 07:33:39
All;
Got the book on the 3010 and need some clarification. Where is the adjust to the hydraulics and will it correct the issue I am having with slow to lower. Fluids all check good and were recently replaced at the dealer.
Thanks
Jason
Glen in TX
07-24-2006 09:21:46
 Re: 3010 Hydraulics go up OK slow to go down? in reply to GnRPaint, 07-24-2006 07:33:39
The operators manual should show a good pic of that?? Facing rear of tractor and right above RH remote outlets should see throttle valve with a screwdriver slotted screw and jam nut. Loosen jam nut and turn screw in for slower or out for faster rockshaft drop. You may need to adjust it again when you go from a light load on rockshaft to a heavy load and vice versa.
Glen in TX
07-24-2006 09:25:40
 Re: 3010 Hydraulics go up OK slow to go down? in reply to Glen in TX, 07-24-2006 09:21:46
Ohhh, Same thing on remotes for adjusting speed on them there is a slotted screw and jam nut under hood on the selective control valve boxes pointing forwards and you turn them in, CW for slower and out, CCW for faster.
G/MAN
07-24-2006 07:38:31
What are you having troubles with that's slow? The rockshaft or remote cylinders? If the rockshaft, there should be a throttle screw that controls the rate of drop of the rockshaft.
GnRPaint
07-24-2006 07:40:23
 Re: 3010 Hydraulics go up OK slow to go down? in reply to G/MAN, 07-24-2006 07:38:31
The rockshaft..... ..
