JD D HEELP ! ! !
B W Johnson
07-23-2006 06:54:18
This darn thing will run for 30 - 40 sec an dies like out of gas. I have checked there is a full stream comeing out the drain on carb. full stream out of tank , have cleaned carb out 2 times in carb cleaner. Have run out of ideas. Runs perfect for the short time. thanks for any help BWJ
Loren in Iowa
07-23-2006 18:51:52
 Re: JD D HEELP ! ! ! in reply to B W Johnson, 07-23-2006 06:54:18
Had a similar problem on our D. The vent passage for the carb bowl was plugged. It would use up the gas in the bowl, and couldn't get any more in. I believe you can pull your air cleaner off, and run a piece of wire through that vent hole.
B W Johnson
07-23-2006 14:15:14
Glen thanks, Looks like go back to sq 1 reclean and finish the job complete, didn't take load valve out didn't see it or was afraid mite twist it off. Have to choke it to start, but after it dies wate 30sec will start back up run for 30 - 40 sec again. Mag has been rebuilt an is hot will set you down when it hits you. I belive you are correct on the carb. I will try it again. thanks BWJ
Glen in TX
07-23-2006 09:51:18
BWJ, A little more info of what year D and what carb might help? Where do you have the carb needles set at now? Does it start well but just dies? Good fire, hot blue spark after it dies? You just might try it with the air intake unhooked and see what happens and if it runs good then start looking at cleaning out grease, dirt, or mud daubers nests out of the air cleaner. If those don't help probably go back to cleaning and checking carb more, pulling the center load nozzle for cleaning and removing all plugs to clean other passageways more. Post back and let us know more.
