50 Fuel Pump
Texas Denny
07-22-2006 20:48:58
I need some help to understand the oil lines running to the fuel strainer. The owners manual says these must be hooked up to get fuel to flow as oil pressure opens a valve. But neither line is connected. Would that mean that the valve has been removed since the tractor runs with out it? A man at a tractor show told me that it was a fuel pump. Don't see how that could be. He also said that if the diaphram breaks, the fuel tank empties into the engine. Is that so?
Thanks,
John51
07-23-2006 04:43:42
 Re: 50 Fuel Pump in reply to Texas Denny, 07-22-2006 20:48:58
No, it's not a fuel pump. It's an automatic shutoff controlled by oil pressure. When the tractor is running the pressure keeps it open and gas can flow.Perhaps someone took the diaphram out and now fuel can flow without oil pressure. Will gas drain down into the crankcase? Sometime, probably. The float and valve in the carb should not allow that to happen,BUT that's why there is a shut off.
Texas Denny
07-23-2006 11:06:00
 Re: 50 Fuel Pump in reply to John51, 07-23-2006 04:43:42
Thanks; all my suspicions confirmed.
