2010 Hydraulic Leak
RB70D
07-22-2006 16:50:41
I have a 2010 propane row crop that leaks hydraulic oil out the weep hole just above the drawbar. It is a very slow drip, running or not. It has dual hydraulics and everything works great. Any ideas?
Bob
07-23-2006 10:25:05
 Re: 2010 Hydraulic Leak in reply to RB70D, 07-22-2006 16:50:41
If the tractor has a 3-point hitch, in addition to the PTO seal, there are over a dozen plugs, "O" rings, and seals, in the three-point lift mechanism that sits atop the PTO clutch housing.
A hydraulic leak at ANY of those will cause a drip out of the PTO clutch housing weephole.
Joe Stewart
07-22-2006 18:21:24
Most likely the PTO clutch shaft seal on the shaft that comes out the back of the tranny case - at least that's what it was on mine. Mine leaked for a couple of years before I finally changed the seal. Not a fun way to spend an afternoon, but can be accomplished with service manual and a lot of patience in tow. While you're in there, replace the seals on the PTO case itself and the roll pins on your pto linkage. Good luck.
Vacherie
07-22-2006 22:24:50
 Re: 2010 Hydraulic Leak in reply to Joe Stewart, 07-22-2006 18:21:24
Which service manual did you use?
Joe Stewart
07-23-2006 03:51:22
 Re: 2010 Hydraulic Leak in reply to Vacherie, 07-22-2006 22:24:50
Manual is Deere's SM-2035. Title is "John Deere 2000 Series Tractors." The oil seal I speak of is in photo 140-10-5 with the caption 'removing Powershaft clutch driveshaft'on page 140-10-2.
