DLTX71 OR DLTX72?
Hick
07-22-2006 16:20:42
I grew up on John Deere two cylinders, so I know quite a bit about them, and I was adjusting the carbs at age 14. But this one has me pulling my hair!
I bought a 1946 JD A a year ago. Got a reduced price because it was not runing quite right when they showed up with it. They were IH people, didn't know about JD. (They had desecrated the poor Deere with IH red as a primer!!!!)
The tractor has a gas manifold and the high-dome pistons, so it is safe to say it has been converted to gasoline. Compression was around 85, if I recall correctly.
I DID get it running okay to pull a hayrack full of Gold Wingers last August in 5th gear. It was tricky to get set and I was NOWHERE near the recommended settings. AND I forgot to write them down.
But since then had a well-meaning friend try to adjust the carb, and now I CANNOT get it set again. Looked in the archives last night and got some valuable info. The main nozzle was tight, had a heck of a time getting it out. It was also very cruddy. Got it cleaned up real good and Cleaned the well for it, figured that was the problem. Put it all together, still no power. It will not get enough engine speed under load to close the butterfly down like it should.
What I have to do is open the IDLE jet about 1 1/2 turns (normal) but the LOAD jet will flood it if opened more than 1/4 turn. The needles look good, no groove from over-tightening. From what I can see of the seat for the LOAD needle, it is not rusted or corroded.
The float level in the float bowl is dead on. I checked it with a clear plastic tube on a barb in the drain hole.
I have not cleaned the passages out with the drills. They do allow compressed air through tehm, but I realize this is not a good test. I don't want to spend the money if my problem is something else. I am running my own repair shop and things are tight, money-wise! While working on it today I noticed it is a DLTX72 which is an all-fuel carb. Is this my problem??
Or is it the IH red used for the primer? :-)
Hick
07-30-2006 15:42:27
 Re: DLTX71 OR DLTX72? in reply to Hick, 07-22-2006 16:20:42
Got the drills & brass plugs from Robert's, cleaned out the passages, and with the cleaned out intake stack it now runs like, well, a DEERE!!
It will walk away in 6th gear like it's going to a fire!
Thanks for all your help, Gang!
P Browning
07-22-2006 23:59:35
Hick -- The test Glen in TX gave you should be your very first action.
And if that don't bring relief, check the LOAD & IDLE pathways in your carb. There is a no-wrench test for those over at the JD-H Restoration Site. Go there, and over on the left, one-click on CARBURETORS. Allow time for the piece to come up & then go to page 7 where you will find the test. Please post back and we take it from there.
Hick
07-23-2006 19:59:50
 Re: DLTX71 OR DLTX72? in reply to P Browning, 07-22-2006 23:59:35
Thanks for all the suggestions, guys!
Tried the no-wrench LOAD / IDLE tests and could not get the tractor running good enough to determine anything. Things are going downhill fast.
Pulled the air cleaner cup off and immediately the load setting had to be normal to run and the governor was pulling the air valve off full throttle.
Pulled off all of Dreyfus' sheet metal and took the stack off. The stack was packed with mud dauber nests. High pressure water & air several times over and I got it cleaned out.
With the intake open directly to the carb (just had the L pipe from the air cleaner to carb on) I did the L / I tests. Load system okay, Idle system failed. Pulled the carb off and got all the brass plugs out (had to drill out the end plug for the economizer circuit on the manifold end).
The PDF on the H carbs was helpful, but the passeges on the DLTX71/72 are different. From looking at the diagrams and my carb I am certain I got all the passages found & figured out. Are there cut-away diagrams available for the 71s?
Now for the kicker: The passages (load air in, fuel out; idle air in, fuel out; ecomomizer air in, fuel out) are ALL clear, as far as blowing air (130 PSI) through them. Shooting carb cleaner through them appears to be fully open as well. Using a LED Streamlite also showed those I could see are open. Unlike the H casrbs, not all passages appear to be straight-line bored. The economizer passage takes a jog.
I thought everything was clean when I had the carb off yesterday. Could the open intake with no restriction (the mesh filter element) have affected the idle test? There would be less suction on the system open to the carb like that.
One other thing, is the mesh element of the air cleaner canister removable for cleaning?
Mike M
07-24-2006 08:01:58
 Re: DLTX71 OR DLTX72? in reply to Hick, 07-23-2006 19:59:50
I learned early on to physically and visually check ALL the passages. Basically you can take a small wire and insert it at one opening and see it at the other end of the opening. Pay real close attention to the "secret passage" the horizontal one behind the screw at the bottom of the stem where the 2 vertical ones are to intersect.
Hick
07-24-2006 12:48:00
 Re: DLTX71 OR DLTX72? in reply to Mike M, 07-24-2006 08:01:58
I ordered the drills, tap, and plugs from Robert's this morning.
The weird thing about this is the tractor WOULD idle, yet the idle test failed . . .
Mike M
07-25-2006 04:59:36
 Re: DLTX71 OR DLTX72? in reply to Hick, 07-24-2006 12:48:00
It was probabally sucking the fuel in from the load side. That's why you have to run one down to shut it off at a time to test which side is plugged up as it can run on either side.
P Browning
07-24-2006 00:27:22
Hick -- I believe I would give Robert a call at Robert's Carb & discuss this one with him. (712) 262-5311
When you say the IDLE test failed, I assume that when (at fast idle) you close the LOAD needle the tractor will not keep running - right! This being te case, there remains a part of the IDLE path that is not open.
See also the Robert's carb site -- scroll down to TECHNICAL INFORMATION and then look for something to the effect that the tractor runs and pulls okay but won't IDLE. He shows some passsageway data that may help you. He just does not show the IDLE orifices. (PatB)
Hick
07-23-2006 20:02:08
Uh, never mind the speculation about the open intake. Just remembered I did the L / I test with the air cleaner on, but the cup off, and the Idle test failed then, too.
Ted Dixon
07-22-2006 16:33:35
Go to www.robertscarbrepair.com. He has a listing on there for which carbs go for which tractors.
hick
07-22-2006 16:40:45
 Re: DLTX71 OR DLTX72? in reply to Ted Dixon, 07-22-2006 16:33:35
I guess I should rephrase my question. I KNOW the 72 is for the all-fuel.
My question is: WILL that make this much difference, or is something else wrong?
Spark timing IS correct, BTW.
Hick
07-22-2006 16:30:29
I should add that the inside of the carb looked REALLY good, except for the nozzle being gunked up. The throttle shaft and bushings had been replaced.
Glen in TX
07-22-2006 19:51:57
 Re: DLTX71 OR DLTX72? in reply to Hick, 07-22-2006 16:30:29
Your DLTX 72 carb is indeed the all fuel carb for JD A # 584000 and up. DLTX 71 was the gasoline carb for A # 584000 and up. Try pulling the intake loose on your carb and then see how it runs. Maybe the air filter and stack are plugged with grease, dirt, crud, or mud daubers nests?
Hick
07-23-2006 10:33:09
 Re: DLTX71 OR DLTX72? in reply to Glen in TX, 07-22-2006 19:51:57
My brother just sent me an email about this. He said when the all-fuels were converted to gas, they changed the jet in the carb. Any way of telling if the nozzle is the "converted" one?
He also mentioned the impulse and / or timing had to be changed as well.
Any info on that?
Thanks!
Glen in TX
07-23-2006 11:43:49
 Re: DLTX71 OR DLTX72? in reply to Hick, 07-23-2006 10:33:09
Well, On the nozzle a strange thing you find in the SM2024 Carburetor service manual is the same load nozzle 47-193, R10116R (larger outside diameter in middle) was used on DLTX-71 gas carb and also all fuel carbs DLTX 33,41,& 53. The later all fuel carb DLTX-72 used a 47-310, R10118R load nozzle (same outside diameter tube except step in middle and bottom end larger). So... that may not be a factor at all. Yes, starting lag angle on magnetos was changed from 35 or 30 degrees to 25 degrees for better starting and running on gasoline and distributors 25-30 degrees or maybe 20 degrees depending on which tractor. Did you try pulling off the intake or any of the carb tests on Pat's carb page?? Run some of the tests mentioned before and you just might find something simple causing your problems and then post back and tell us what you found.
Hick
07-23-2006 14:11:32
 Re: DLTX71 OR DLTX72? in reply to Glen in TX, 07-23-2006 11:43:49
Not yet. I did download the Carb PDF that Pat metnioned and printed if off. Lazy Sunday afternoon; will try the tests and what you fellers mentioned tomorrow.
Automotive & motorcycle carbs are a piece of cake for me, but these "simpler" JD carbs are throwing some curves at me! That PDF was real informative, and pointed out some things I was not aware of.
Question about the Magneto timing: You menitioned the lugs are changed. Do I still set the impulse by the marks on the flywheel?
Glen in TX
07-24-2006 07:45:13
 Re: DLTX71 OR DLTX72? in reply to Hick, 07-23-2006 14:11:32
Just concentrate on the other things for now and check the timing if you need to but leave the magneto alone for now. You'll use the flywheel marks to set or check the timing. If you need more timing info let us know but it gives that in operators manual and I&T JD-4 shop manual.
