4640 SCV Questions
James Williams
07-21-2006 21:01:48
I have a 1981 4640 with 3 scv's. I'm having problems with 2 of them leaking down. When I'm hooked up to my wheel disc or wheel scraper, the cylinder will slowly leak down from the raised position. Could this problem be in the breakaway coupler? Or is it in the scv housing. The previous owner installed the iso conversion kits on the breakaway couplers. I would like to switch them back to John Deere style. The reason for this is all my other John Deeres have the old style. I figure if I need to overhaul the couplers, now is the time to convert them back. Do I need any parts to convert them back John Deere? Thanks for any help you can give. James
Tx Jim
07-22-2006 04:02:32
 Re: 4640 SCV Questions in reply to James Williams #2, 07-21-2006 21:01:48
Switch hoses in each scv so lever has to be moved in opposite direction and see if this stops cylinder movement. Also packing on piston in cylinder may be causing leak-down. Tx Jim
James Williams #2
07-22-2006 16:33:28
 Re: 4640 SCV Questions in reply to Tx Jim, 07-22-2006 04:02:32
I switched hoses in both scv's and it still leaks down, but no fluid hits the ground. Now I have a new problem with #1 SCV. One side of it is not working. It will raise disc but not lower it, or vise versa if I switch the hoses. It's when I pull back on the lever it doesn't work. I see the hoses jerk but the cylinder won't move. I don't know where to start. Could I have two bad scv's at the same time?
Secret Squirrel
07-21-2006 22:06:49
If oil is not leaking outside the cyl, or on the ground at the couplers, then it is probably internal in the upper scv. The scvs are basically 2 parts. The upper is the valving for control, and the lower is for connection. If it has been converted, you will have to buy the original barrels (2)and their related parts, and a kit for each. There are oring kits available for the upper part, as well as the valves. You are correct, it would be as good a time to do it all.
