G Compresion
DGK
07-21-2006 14:57:45
I bought this G that was just overhauled but would hardly run, not much compresion, checked timming, valves ect. Now I have head off 1 piston out. Have arround 60ths ring end gap on top ring. Fliped head up poured gas on top of valves and they held gas. Not sure where to go next. everything looks new inside. Thanks Doug
johns48b
07-22-2006 15:15:38
 Re: G Compresion in reply to DGK, 07-21-2006 14:57:45
seems like you jumped in and went to far before checking for more commom problems. did you clean the carb good and check for restricted air flow? was it getting plenty of gas to carb? was it timed correctly? i expect that if you put new rings in it and put it back up that it will still run bad until you've checked a lot of other things out first. good luck.
Duane Larson
07-21-2006 20:55:52
DGK,
Compression ring end gap for a G is given as 0.039 - 0.053", so your's is over the upper end. It depends on what the overhaul involved - were the cylinders bored - were new rings installed in the old bore (sounds like the case) and were they seated? You might try honing the cylinders enough to get a cross-hatch pattern and hook the G to a dynamometer or good belt load to get the rings seated, and then see what the compression is. Also check to make sure the ring end gaps are not lined up on the piston.
