1968 JD 4020 injection pump
JD4020JOE
07-21-2006 00:36:38
I recently bought a late 60's JD 4020. It ran great with plenty of power after servicing was complete. I decided to put it to work and went discing when i noticed the engine was pulling down and losing power and eventually died. I thought loss of fuel was the problem so i changed the lift pump on the side of the engine and blew out the inlet line to make sure nothing in the tank could be blocking the passage. It started back up after priming and ran for about 10 seconds when it pulled down and died again. Any help or ideas would be greatly appreciated. Could it be the governor inside the injection pump?
Tommy Eldridge
08-02-2006 18:48:58
 Re: 1968 JD 4020 injection pump in reply to JD4020JOE, 07-21-2006 00:36:38
If it has a roosamaster pump the inlet line fitting(line frome tank to pump)has a glass ball in it. You can take the fitting out and take a punch and knock out the ball from the back side. I would try this before rebuilding the pump. I have done this on alot of roosamaster pumps and they when back to running fine.
donmyeil
07-21-2006 13:43:59
The governer ring in the injector pump is comming apart and plugging the return fitting. Remove the timeing window on the side of the pump and it will run fine other than a mess. The pump needs an overhaul. Don
Tx Jim
07-21-2006 04:14:34
Check the fuel return line to see if it's blocked as this will shut off engine. Also check fitting that return line attaches to on inj. pump for small black plastic pieces that would be parts of govenor ring in inj. pump. Tx Jim
