70D dead miss
Mike in Shendoa
07-20-2006 20:16:57
Friend of mine's 70D is giving me a fit--only runs on right cyl while under no load conditions-is wet stacking I think because of this. If you load the engine(put it in 6th gear and slip the clutch a little)it will come in and run perfect, injector spray looks good, Even switched with other side-still misses,but could it be the left pump or????? This happened after sitting for a month or so. All valves appear to be ok,clearences too.
Johnny Popper Fan
07-23-2006 18:43:51
 Re: 70D dead miss in reply to Mike in Shendoah Valley, 07-20-2006 20:16:57
Hey Mike,
Where are you located at in the Shenandoah Valley? Im close to Harrisonburg!
07-23-2006 06:55:30
mj-thanks for the info-I'll head in that direction after bit, right now I'm suddenly dealing with parents health problems.
mjbrown
07-21-2006 06:25:45
Has anyone had the rack off the pumps? If so they could be a little out of sync. Are the pushrods to the pumps set right? Scribe lines moving the same in the little window on top of the pumps?
