3020 time to rebuild injector pump?
Huckleberry
07-20-2006 19:39:48
I bought 3020D with 4700 hrs on it. That's all the history I know. Has been running great ~ now has 5000+ hours. Had to road tractor a ways...Lost power in 8th gear up hill...acts like no fuel. press in clutch---plenty of fuel. Once I get in field [bush-hogging] and up to full operating temperature...runs "okay" but just not quite right...sometimes almost sounds like a miss. My first diesel tractor. How many hours on one of these before one can expect to rebuild the injector pump. Fuel filter has 100 hours on it. ALSO?? there is a large air bubble in the top of the fuel transfer pump---is there supposed to be absolutely no air in that glass bulb? ...Thanks for any replies.
jdemaris
07-21-2006 05:12:11
 Re: 3020 time to rebuild injector pump? in reply to Huckleberry, 07-20-2006 19:39:48
There are several components in the injection pump that go bad with age - having nothing to do with amount of use. So much depends on how old the pump is - and I assume you have no idea when, or if it's been rebuilt. The original engine mounted transfer pumps with sediment bowl just about always have an air bubble - that's normal. Very often those pumps wear out in a way - that they do not work from the engine turning, but WILL work with the hand-primer - and that can fool you. The engine-side linkage of the fuel pump that rides on the engine's camshaft is the first to wear out - but the hand-primer on the outside does not. If suspect - just take the pump off and test it by hand. Also - check the fuel fitting at the bottom of the fuel tank - it can plug pretty easy.
Tx Jim
07-21-2006 04:22:26
Hours of use on an inj. pump depend alot on how clean the fuel and how often filters were changed. I've seen tractors go over 10,000 hrs before inj. pump overhaul. I would also check the fuel flow coming from tank to be sure it's no restricted. Tx Jim
Bob
07-20-2006 21:22:13
Start by changing the fuel filter.
The bubble in the top of the fuel pump glass bowl is NORMAL.
