JD 50 Transmission
Ray in Penna.
07-20-2006 19:03:22
I have a 1954 JD 50 and it keeps popping out of gear ( 1st & 3rd). Today it popped out of 5th. When I went to park it, it would not come out of 2nd gear. I pushed on the shifter and It came out of the housing! I had noticed it made some loud rumbling in 4th and 6th. So I have not used them. Had the tractor for about 6 months. I guess this is major transmission problems or is this just bearings? Can someone help!
buickanddeere
07-21-2006 17:10:17
 Re: JD 50 Transmission in reply to Ray in Penna., 07-20-2006 19:03:22
The good thing is just about any styled B to a 530 can be a donor tractor for most trans parts.
Tyho
07-20-2006 21:44:18
I was given my grandfathers 630. It had not run for almost 6 years. I got her going and started to use her. In about 20 hours of operation, she started to make some grumbling in the gearbox. Then she jumped out of gear a couple of times. When I tore down the gearbox ( transmission) I found that the sliding shaft bearing on the left side had come apart and allowed the slideing shaft to bounce around and pop out of gear. This whole thing was caused by the bearings having rusted over the time she sat around doing nothing for all those years. Just my experince, hope yours is not so bad.
55 50
07-20-2006 20:15:24
The "loud rumblings" would seem like major trouble to me, but you can never be sure until you look at it. I had a shift lever come out of the housing too. It needed a new shift lever, snap rings, fulcrum ball, ball socket and fulcrum seal. Has worked fine ever since replacing those parts. (The snap rings and the grooves they fit into had rusted and worn badly-probably due to lack of servicing by previous owners, the service manual plainly states to change the transmission oil regularly to prevent moisture buildup) The bottom snap ring may have come off and fallen into the transmission, mine didn't and was still hanging on the shift lever although it was out of its groove. If yours did fall into the transmission, then you have a bigger problem to get that out so it doesn't get into a gear and break teeth etc.
Ray In Penna
07-22-2006 04:25:24
 Re: JD 50 Transmission in reply to 55 50, 07-20-2006 20:15:24
Thanks for the info. I plan a major tear down this fall. Right now it is stuck in 2nd gear so I can move it into the garage when ready. Other than that the tractor is in great shape.
