45 Trip Loader on 51 B
Green 51
07-20-2006 17:20:06
Need some information about the axel mounting brackets.
Have a pair that that have been butchered up pretty bad.
Need to know how many mounting holes to use.
Looks to me like someone took a torch and cut in two extra.
Also a piece was welded on the fender mounting holes. I know this is not standard, is it a good thing to do.
Thanks for your help in advance.
F-I-T
07-21-2006 08:43:36
 Re: 45 Trip Loader on 51 B in reply to Green 51, 07-20-2006 17:20:06
third party image
Here are some photos that someone was kind enough to send to me when I was in the process of converting some of the straight 5/8" flat plate brackets back some semblance of original. I believe these to be original for the two-cylinder mounting style.
Sorry the phots are big, and I hope they help.
Frank
Mike M
07-21-2006 04:35:29
I have seen two styles. One uses a big thick plate with 4 holes each side and the loader mounts offset to the right. Mine had extra angle iron added to go over the top and bolt into fender holes of a flat top axle. I have also seen some that I think just had 2 holes inside of each u shaped bracket these were more centered on the tractor and were on round axle housings and had a rod that went from the top of the bracket to one of the studs on the back of the axle to stiffen it.
I'd say the more bolts the better.
DSK
07-20-2006 19:20:46
The original 45 brackets used just the 2 inside mounting holes on the axle housing with 2 pipe guides welded to the outside designed to fit over the outside studs with the original axle nuts in place on the studs. This setup is ok if the frame braces are properly adjusted and the loader is not being used as a bulldozer. If you have to rebuild the brackets any way, I would weld a 5/8's plate to the bottom of the bracket and drill 4 holes to use all the mounting holes available, the extra strength can't hurt. The big mistake made with these loaders is letting the threads seize on the frame braces and not tightening the braces enough to put the lifting load on the tractor frame and not the rear axle of the tractor.
