Fuel shut off
Pitalplace
07-20-2006 15:25:32
Well the new tractor in the fleet just had the oil and filter changed and parked in the shed read for the next mission. Went to start it today and not. After several tries I smelled a lot of gas. Pulled the dip stick and got about five gallons of gas. Anyway I will assume that it is the fuel shut off and have called Mother Deere. They have the diaphragms and they have A 4978 washer, valve seat, rubber. I ask if they have a rebuild kit with no luck. If someone knows the part number for the rebuilt kit (if there is one) please let me know. Do I need any other parts other than the diaphragms and the washer. Thanks Byron
easydoesit
07-21-2006 12:55:03
 Re: Fuel shut off in reply to Pitalplace, 07-20-2006 15:25:32
Byron, I open the petcock and drain my carb bowl when I put any tractor back in the shed. I leave the petcock open in storage. If something is leaking I know it.
DSK
07-20-2006 19:29:57
All you need to rebuild the automatic fuel shutoff is the diaphrams and the plastic washer. It is not available as a kit and the parts will have to be ordered seperately. Make sure you clean all the parts thoroughly before you reassemble.
johns48b
07-20-2006 18:38:01
byron, you need to replace the needle valve and seat. also check the float lever after you put it back together. also check the float to be sure it hasn't developed a hole in it and its to heavy to work right. man i hate changing the oil and somrthing like this happens. i guess it could be worse like the time i built a truck engind and forgot to put the oil plug back in the pan and poured it out on the ground. at least your way you might could use the oil in a ghain saw for blade lube on cold days. i don't know if it would eveporate out of the oil some if you left it setting out side in a container like a five gallon bucket with the lid off. it might do to burn a trash pile with, but you really have to be careful with gas especially on cloudy days. the gas will hug the ground and spread out a long ways around the trash pile instead of going up into the atomsphere. (trip to emergency room for burns, made a believer out of me)
