730 Surge
Coastie Jim
07-20-2006 14:56:28
Got the 730D back together and she runs great. Just got one thing left. I got the injection pumps timed right on and the rack settings are correct but she has about a 50 rpm surge below 800 RPM with no load. Hoping you all might have some ideas. Thanks!
Jim
GPULLER
07-21-2006 08:30:26
 Re: 730 Surge in reply to Coastie Jim, 07-20-2006 14:56:28
After I overhauled my 720D it too had the surge you have at the same RPM range. I double checked everything, pump timing, injector lines, torque on the injectors, rack movement, governor and everything was OK. I put it on the dyno and worked it for an hour and the surge went away. Maybe it was surging because of a new tight motor, I don't know. Maybe try to work it and see if the surge clears itself.
F-I-T
07-20-2006 15:28:08
Is the spring on the speed control rod (under the cover on the left front of the governor, sort of sticks forward) on the loose side, allowing it to maybe bounce a bit at lower speeds? If you tighten that at all, then you will probably have to go back and re-adjust the top end and idle stops. Also, you might check the rack return spring on the right hand-end of the rack to see if it is weak, again allowing it to bounce.
That's just a couple of quick thoughts.
Frank
