sandblasting problem
joshn
07-20-2006 01:18:18
The wheel clamps off of a styled D have been sand blasted(actually glass beaded) several times and after each time they rust up almost immediately. But not all of them only a few of them. If calcium chloride came into contact with these parts could that be the cause, or is this normal? The air compressor setup is at a powerplant and has filters to remove moisture.
Thanks
joshn
07-20-2006 14:31:19
 Re: sandblasting problem in reply to joshn, 07-20-2006 01:18:18
Thanks for the replies...I think the some of the cast iron parts had the calcium chloride leak from the tires and onto the rims, clamps etc.....I will try the advice you gave, thanks
F-I-T
07-20-2006 07:16:16
joshn:
You need to use an acid product to remove the remnants of silica from the sand that are stuck in the tiny craters of the steel, or in this case cast iron grain. If you don't, they will draw moisture from the sir and opo underneath your paint down the road. I like to use any of the phosphoric acid products available at the building supply and car parts stores, like Ph-Opho-Ric+, but NOT MURIATIC ACID. The H3PO4 (Phosphoric acid) will dissolve the old sand deposits, remove any of the red rust that is forming on the fresh metal and convert it into the inert black oxide which will be stable and paintable, and inhibit further rusting by providing a thin phosphate coating.
Now, you still should not store those parts near anything like table salt, potassium salt, tire calcium, side walk ice melter (same as tire calcium, CaCl3), nitrogen fertilizer, other ammonia products, etc. Not near a strong oxidizer, see? You really need to prime those parts as soon as you can or at a minimum get some H3PO4 and treat them. If you are not going to prime them right away, then oil them and degrease them later prior to paint.
Frank
Frank
P Browning
07-20-2006 06:52:14
If you are saying that you have steel parts in or near a chlorination apperatus, you bet that's the cause! I once knew a fellow who built a small shed out behind his house to contain pool supplies and thought, while he was at it, it would make a really great place for some of his tools. Well, the result was a disaster. Inside of two weeks, those tools showed more rust than if they laid out in the open all year. Calcium Chloride (The Salt) will do a fast number on steel. (PatB)
Ken52M
07-20-2006 06:34:54
Go to the Restoration Tips board. Lots of expert help there. I think you need to etch them afer cleaning. KB
