4010 fan belt change
R. John Johnson
07-19-2006 20:19:10
Looks like its time to change the fan belt in the old girl. She still has the original style hydraulic pump coupler with the two plates. My question is about the bolts holding the coupler to the plates. The heads of the bolts are cross drilled like they were meant for a keeper wire, but no wire is in place. Do I just take the coupler apart, change the belt and re assemble or is there more to it?
Thanks
John
ET
07-20-2006 09:10:06
 Re: 4010 fan belt change in reply to R. John Johnson, 07-19-2006 20:19:10
I have found that a drop of blue loctite is easyer and faster than the wire. Torque them to 35ft.lbs. if you can get at it with a wrench.
msb
07-19-2006 20:38:15
The bolts had wire in then when the tractor came from the factory.Replace that setup with the 4020 style coupling.
Bob
07-19-2006 20:47:38
 Re: 4010 fan belt change in reply to msb, 07-19-2006 20:38:15
Or, at least use Nylock nuts on the coupler bolts.
