8420 FWA
schrocky
07-19-2006 18:57:12
has anyone else out there had issues with this series of tractors? we purchased new when introduced 4 yrs ago and what a piece of crap. We have have all kinds of issues and JD just shrugs and sends another bill. Now we are having trouble with the ILS suspension controllers and it is over $3000.00 per side to repair this tractor has less than 2000 hrs. Beautiful to look at fun to operate but wow exspensive
buickanddeere
07-21-2006 17:12:58
 Re: 8420 FWA in reply to schrocky, 07-19-2006 18:57:12
There maybe more problems with the dealership than with the tractor.
G/MAN
07-20-2006 07:34:49
ILS suspension controllers? What exactly is a "controller"? I've got a lot of 8020 experience, and the ILS has been one of the more trouble-free systems on those tractors. Just worked on an 8520 where the suspension would settle over a period of a few days, when it's not supposed to settle more than an inch per week, but in-field performance was not affected. Apart from that and a broken output gear at the front differential on the same tractor - which carries a 16-row semi-mounted planter and two 500-gallon side-mounted saddle tanks AND a full rack of 22 weights, they seem to hold up fine. I've replaced several position sensors, however. Clarify exactly what the problem is, as they did come out with a PIP for the upper suspension pins, as they were turning and wiping out sensors. Only other major issue with the 20s has been ongoing SCV issues. They had an excellent valve in the 8000s and 8010s, but went back to the drawing board on the 8020s in order to provide more precise flow control, in response to customer requests for just that. The new valves are such a complicated casting with so much machining that they're fairly flimsy, and leaks and hose ejection have been an issue. Early tractors had any number of ongoing issues and PIPs for that, the later tractors are much better. How old is yours? There were also some injector issues with the engine, which were pretty much taken care of with the fuel filter improvement, and the change to a 10-micron primary filter and 2-micron final filter. A fuel system with tolerances in the millionths of an inch and injection pressures up to 22,000 psi tends to require clean fuel for some reason. So what other issues have you had?
