Burning lots of oil
BobinKS
07-19-2006 17:34:53
I think I figured out what I did wrong but thought I would ask before I either start it up again or tear it apart looking for something wrong. I started my 38A up this evening, it was still about 100 degrees out, wife wasn't too happy about that. Anyway, it started up and was blowing smoke out the exhaust including leaving oil dots all over my new paint job. There was oil leaking out around the head gasket, valve gasket, manifold gasket, and where the exhaust pipe meets the manifold.
The thing is I pulled the tractor out two days ago to do some painting and left it on a fairly steep downhill. I think oil was setting on the rings for two days and just leaked by and was waiting in the cylinders for me. It did seem to be running better by the time I nursed it back into the barn and the smoke seemed to be letting up. Though the smoke from the wifes ears when she showed up with a drink of water kind of obsucured the whole barn and I had to head down to the house to put out the house fire if you know what I mean.
Any input, what kind of down angle would be too much?
johns48b
07-19-2006 19:46:05
 Re: Burning lots of oil in reply to BobinKS, 07-19-2006 17:34:53
i think p browning may be on to something here. with the tractor sitting on a slop the needle valve may not have shut the fuel off real good, especially if the shut off was left on. i wonder if your oil smells like gas? if it does i would drain it before trying to crank it again. i haul my tractor in an enclosed trailer and i could smell the gas when i opened the doors. i had to change the oil with it up in the trailer and i have the cultivators and planters mounted on this tractor. that was a lot of fun. let us know what you find
johns48b
07-19-2006 17:53:23
i don't know about that early of a model tractor but if it was doing that on my 48 b i would think that the vent pump isn't working. if you had the much oil run past your rings you've got way to much oil in the crank case. your crank case vent may have found a nest of dirt dobbers to move in. i'm wondering what is causing that much blow by around the rings. did this just happen all at once? how long had it been since you ran it last before this? if oil had ran around the rings it would have done it when you cranked it up to get it off of the hill.
BobinKS
07-19-2006 18:02:49
 Re: Burning lots of oil in reply to johns48b, 07-19-2006 17:53:23
I don't think there is any obstruction in the vent but I will check. It last ran on Monday two days before the smoke. It had not offered any smoke prior to this. The oil pressure was fine while it was running. It ran a little rough to begin with and as I got it pointed uphill it started to clean up quite a bit. I'm pretty sure the oil level is good, though that is on my list of things to check.
P Browning
07-19-2006 18:14:02
 Re: Burning lots of oil in reply to BobinKS, 07-19-2006 18:02:49
BobinKS - When wierd things like this happen, always be on the lookout for thinning of your oil at the same time you check oil level. Check for thinning when the engine is cold. Thinned oil won't feel quite as slippery in your fingers. If the fuel is left on for a spell after putting the tractor away, there can be seepage past the float needle valve right on down into the crankcase. Just a random thought! (PatB)
BobinKS
07-20-2006 14:58:44
 Re: Burning lots of oil in reply to P Browning, 07-19-2006 18:14:02
Is it possible for excess oil to travel along the pipe that brings it to the rocker arm. That may be the problem. The oil level was fairly low when checked and seems to not have gas in it. I'm beginning to think that it may have been that the valve cover was fairly full and after my wife began to talk to me again she said it really started to smoke after I turned it around and was going uphill. So I'm thinking there was a lot in the valve cover and when I went up hill it drained into the engine via the valves. Any reason why it would have done this and how might I fix it?
