44 JD A cylinder id issue, any ideas?
phillip w.
07-19-2006 17:06:04
I"m just taking apart the engine on my 44 JD A for a rebuild and when I pulled the head off I found something I"ve never seen before. The first inch or so of the cylinders are only about 4 1/4" and then from that first inch or so down is 5.5" as it should be, what is this for? I am going to bore it .090 over and put high compression pistons in it and hope this doesn"t cause a problem. Thank you for any help
Glen in TX
07-19-2006 22:34:59
 Re: 44 JD A cylinder id issue, any ideas? in reply to phillip w., 07-19-2006 17:06:04
third party image
I had put this old ad for the inserts over on on vintage ads last year. It shows what you probably have. Every set I've seen in a old D engine had everything real carboned up so I've never tried reusing them and went with the rebore and larger high compression pistons.
Phillip W.
07-20-2006 01:23:49
 Re: 44 JD A cylinder id issue, any ideas? in reply to Glen in TX, 07-19-2006 22:34:59
I knew you guys would know what they were. My cylinders are very carboned up around the inserts. Thank you for all the help.
Duane Larson
07-19-2006 20:25:18
Phillip,
You likely have a set of Hollingsworth High Compression Inserts. Raphael Hollingsworth of Ollie, IA received a patent in 1948 for the concept, and sold them into the mid 50's (Tractor Supply sold them in their '52 and '53 catalogs). They were available for A's to 584000, B 96000-200999, D 109944-, and G 13000-, and possibly others (also IH, AC, and Case). I haven't found a Hollingsworth brochure (anyone have one?). They also sold cold manifolds. I have been told that the inserts led to heating problems and were a poor man's way to high compression. His health deteriorated in 1956 and he died in 1961.
Duane Larson
07-19-2006 20:23:43
Phillip,
You likely have a set of Hollingsworth High Compression Inserts. Raphael Hollingsworth of Ollie, IA received a patent in 1948 for the concept, and sold them into the mid 50's (Tractor Supply sold them in their '52 and '53 catalogs). They were available for A's to 584000, B 96000-200999, D 109944-, and G 13000-, and possibly others (also IH, AC, and Case). I haven't found a Hollingsworth brochure. They also sold cold manifolds. I have been told that the inserts led to heating problems and were a poor man's way to high compression. His health deteriorated in 1956 and died in 1961.
johns48b
07-19-2006 17:56:38
i know i'm from the country, but i've never heard of compression building inserts. are they for real?
Mike M
07-19-2006 17:28:40
It sounds like those may just be a set of compression boosting inserts. Clean everything up real good and see if it looks like they come out.
phillip w.
07-19-2006 17:32:51
 Re: 44 JD A cylinder id issue, any ideas? in reply to Mike M, 07-19-2006 17:28:40
They do look like they will come out, I'm guessing I do not want those in there if I'm putting high compression pistons in it?
Mike M
07-19-2006 17:39:07
 Re: 44 JD A cylinder id issue, any ideas? in reply to phillip w., 07-19-2006 17:32:51
I think you want them out of there as I think you can get pistons that will be plenty high.
