Herc36A, First, adjust the governor - carb butterfly rod linkage as JohnT says. I set mine between 1/2 and 1 hole short. That ensures the carb opens fully when the governor is calling for full open. It is possible the length of this rod may need adjustment to achieve the above setting and this can be done by removing the rod at the governor arm and making the length adjustment. Next, the rod length from the hand throttle to the governor spring needs to be adjusted, as do the bolt stops for the hand throttle. If you have separated the threaded end piece of the rod, screw it back on the rod to a middle position as a starting length. Pull the throttle lever back until the spring just pushes the governor arm as far as it will go toward the front of the tractor, and adjust the throttle lever stop bolt. Pulling the hand throttle back any further just bends the spring against the governor arm. This is a first setting of low idle speed. Start the tractor, push the hand throttle to wide open position, and measure the fast-idle rpm with a tachometer. Move the "wide-open" throttle lever stop to get the correct fast-idle speed (1075 rpm for an unstyled A). If you can't achieve fast idle rpm, adjust the length of the throttle lever - governor spring rod to provide 1075 rpm. This may be an iterative process - if the throttle lever-governor spring rod is adjusted, the idle stops may need readjustment, etc. Also keep in mind the governor spring discussed above may need replacement if you can't get high idle with reasonable settings of the rod length and adjustment screw. Or you can try and add a second spring to stiffen it up ..... A new spring is B273R and costs $34.38 from your dealer.
