Good, bad otherwise? jd790 4x4
Nylon
07-19-2006 15:43:59
Neighbor wants to sell me his 790. Has a 60 inch mower dexk and a 6 foot blade. Want to know if this is a tried and true tractor by those who own or use one. Thanks for any info.
John
Russ from IA
04-20-2007 08:21:32
 Re: Good, bad otherwise? jd790 4x4 in reply to Nylon, 07-19-2006 15:43:59
Yesterday I bought a 2004 790 with a 300 loader that was a repo. It has 160 hours on it and I gave $9500 but, it isn"t a cream puff. The loader has some scratches as it was used as a loader but, the cutting edge is nice and straight still. The rest of tractor appears in good shape. The fluid filled R4 industrial tires have some spin cuts also. I used it on my 5 ft IH bush hog to mow my ditch and I loved it. The tires didn"t tear up the yard and I didn"t feel like I was going to tip while mowing on the incline. I feel it will be a useful tractor around our 80 acre farm. Good luck.
Mike M
07-19-2006 17:37:35
They still sell that model new today. It is a price fighter model. Less frills and only gear drive,but this can be a good thing as it has less stuff to go bad. I think those are entirely made by Yanmar and that's a good thing ! The old 650,750,850 etc.are among the toughest compacts every built. I think the 790 is just an improvement over these old models as it offers power steering and live pto standard. So if you can live with a gear drive mower tractor and not a hydro I doubt you will find anything better.
Brent in IA
07-19-2006 16:53:13
I had a 790 4x4 at work. It came with turf tires which were no good for anything except grass (which is what they are supposed to be for I guess...) so we switched them out for the industrial tires with flat bars. They didn't tear up the grass and they were great for light tillage. It was an economical machine, great hydraulics, and no issues in the 4 years we ran it.
morningwood
07-20-2006 07:31:33
 Re: Good, bad otherwise? jd790 4x4 in reply to Brent in IA, 07-19-2006 16:53:13
I have a 770 ( predecessor to the 790 ) and I have not had any issues with it. I bought it off of ebay with 450 hours and have put about 200 hours of trouble hours on her. I have seen them advertised new with a loader for 12,500, just to give you a idea if you are getting a good deal or not. I am not sure what you are planning on doing with it but having a loader is a back / life saver. I have turf tires on mine and it is great for the grass but gets easily hung up in any kind of mud, it does okay on dry dirt. That is the reason I talked momma into letting me get two tractors, more toys to play with.
Scott
Nylon
07-20-2006 10:10:58
 Re: Good, bad otherwise? jd790 4x4 in reply to morningwood, 07-20-2006 07:31:33
Thanks for the great info guys. I have a 4020 with a 7 foot 148 loader on it so I am covered in that department. Need more of a mowing machine for both yard and ditches...some of it low and wet parts of the year. Hoping that it is agile enough to mow the yard as well.
Thanks,
John
morningwood
07-21-2006 06:36:09
 Re: Good, bad otherwise? jd790 4x4 in reply to Nylon, 07-20-2006 10:10:58
I have a 5 foot Land Pride mower that I use behind my 770. It is more than agile to mow with even with a loader in the front. It would be a dream without the loader but you are still not looking at a zero turn either. I would recommend a 5 foot mower over a 6 footer because if the grass gets too high I even run into problems try to spin her fast enough to get a good cut.
Scott
