B Pistons A 1239, 90 Over?
Lencollings
07-19-2006 10:36:21
Pistons inside are stamped A1239: stamped on the side of the piston. I measured the diameter of the piston and got 4.725 at the skirt 90 degrees the wrist pin. Does anyone know if these are M & W 90 Over?
Mike n Mo
07-20-2006 09:21:44
 Re: B Pistons A 1239, 90 Over? in reply to Lencollings, 07-19-2006 10:36:21
I would offer an educated guess that they are 0.045" over. Stock bore on a late B is 4.6875 giving a differencs of 0.0375" from your piston measurement of 4.725". Add piston-wall clearance of 0.0075 and you have 0.045".
Earl-IL
07-20-2006 19:29:12
 Re: B Pistons A 1239, 90 Over? in reply to Mike n Mo, 07-20-2006 09:21:44
Thanks Mike, I overlooked the wrong size on the rings. Earl
Earl-IL
07-19-2006 19:08:15
Len, Your pistons are Clevite, Gould -Clevite ,White Machine Works. The same manufacture under different ownership. Duane Larson can give you the complete history of the company.Rings are available from Hastings. If you need help email back. Earl
