Batteries for 2130
Art Smith
07-19-2006 08:30:14
I have trouble starting my 2130 which has one large 12 volt battery. It does't seem to turn it over fast enough to start. I suspect that it should have two batteries in order to speed up the cranking speed. Am I onthe right track?
daryl kennedy
07-20-2006 16:15:11
 Re: Batteries for 2130 in reply to Art Smith, 07-19-2006 08:30:14
am little trick is as you are cranking it turn the steering wheel at the same time
it will make the engine turn over easier
buickanddeere
07-20-2006 21:45:52
 Re: Batteries for 2130 in reply to daryl kennedy, 07-20-2006 16:15:11
Mother Deere sells a hydraulic pump destroker for less than the cost of two six packs of beer. The automatic electric destroker goes for about $300.00 .
buickanddeere
07-20-2006 15:04:47
Mother Deere used two batteries to get 1200-1400 amps at 12v. Very few single batteries can supply over 1000 CCA. Even if the cables all look clean and fine. Check and shine them up anyways and measure for voltage drops. Take the chassis "ground" connection and move it to a starter mounting bolt.
