Blowby
MAD4JD
07-19-2006 04:42:12
Not a Deere but is a tractor. A Ford 1520 that has excessive blowby and actually blows some oil out of the vent tube. I have not had an oppertunity to really check it out myself. What could be the underlying cause of this? Any ideas and suggestions appreciated.
MAD4JD
johns48b
07-19-2006 18:05:22
 Re: Blowby in reply to MAD4JD, 07-19-2006 04:42:12
have you been using ether to crank it with? i've seen holes in pistons and skirts knocked off of them from using ether to crank the engine with. probably just bad rings. has it been overhauled lately? have you "rode it hard and put it up wet"? engines do wear out.
mad4jd
07-20-2006 16:51:23
 Re: Blowby in reply to johns48b, 07-19-2006 18:05:22
The tractor does not belong to me, so I can not say as to the eather or running hard and putting away wet. I do think that the people who use it have been pretty good to it. It has been used to mow with (belly mower on lawns and along streets and around lagoons). It only has 1000 hours on it.
jas
07-19-2006 13:07:13
IS the oil overfull? Does it start good? Does it smoke blue or excessively? Usually blowby means wore out.
tstex
07-19-2006 08:30:15
MAD4JD,
You probably have an issue with one of your exhaust side valves...not familiar with that tractor, but here the the link to the Ford side of the discussion forum:
Link
Good luck,
tstex
MAD4JD
07-19-2006 05:43:20
This is a diesel tractor.
