JD 467 low voltage warning / net wrap trouble
Dan Mike Johns
07-18-2006 17:42:41
We use both a 4240 and a 4430 to bale with a 5-year old 467 with net wrap. We are having trouble with the net wrap cutting due to a "low voltage" indicator on the baler monitor.
Any suggestions? We've changed & rebuilt the alternators, but that "fix" doesn't seem to last long, if it helps at all.
cannonball
07-19-2006 03:50:20
 Re: JD 467 low voltage warning / net wrap trouble in reply to Dan Mike Johnson, 07-18-2006 17:42:41
try the connection at the wrap motor, mine was doing that yesterday and i spread the prongs and it stopped.. may GOD bless the usa
Tx Jim
07-19-2006 03:46:15
My JD 467 started having twine tying problems and the low battery thingy flashed. I ran a new power cable direct from battery not using the covenience outlet that came in tractor and fixed my problem. Tx Jim
matthies
07-18-2006 21:16:42
Since both tractors are having the same outcome, start checking the harness on the baler or from the power source to the monitor. Could be a bad ground also. Did you happen to try a different monitor?
